vtec pressure
Discussion in 'HYBRID -> EG-EK / DC' started by delsol-R, Jun 13, 2005.
  1. delsol-R
    delsol-R Junior Member
    i swap jdm b18c5 , but the jdm engine doesn"t have vtec pressure switch , can any one tell me what i need to do with the pressure switch or i dont have to do anything with it ?
  2. pissedoffsol
    well, there is no such thing as a jdm b18c5. b18c5 = us itr. b18c spec r = jdm itr.
    now, the jdm itr motor doesn't have a pressure switch, you're right. and neither does the jdm p73 ecu look for it.
    if you're using a different ecu, you need to get it chipped to not look for said switch. almost every management out there has the option to disable o2, knock, and pressure sensors.
