Vtec Question
Discussion in 'General Tech and Maintenance' started by 9integragated1, Feb 18, 2003.
  1. 9integragated1
    9integragated1 Junior Member
    Is it possible to have a automatic transmission with a VTEC engine? If so will the engines performance be the same?
  2. sportlinecrx
    sportlinecrx Banned
    yes. vtec has nothing to do with the tranny. it has to do with the engine's valve timing and valve lift. the engines will perform the same, BUT the automatic has larger, harder-to-get-moving gears, and pre-determined shift points. thats why automatics are slower. also, automatic transmissions use some of the engine's power to help it shift.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Don't they also have milder cams?
  4. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i dont know if i believe that myth...
    why would honda waste the money to make two separate cams for automatic and manual cars??
    if they are machined from a billet block, then that means that they have to have two separate cnc or other machines to do that work and those are expensive... if they only use one.. then they have to change the program to make them...
    it just makes more sense that they made one set of cams and put them in all the engines and only the tranny changed... but i could be wrong...
  5. xj0hnx
    C.C.TX.
    Your right it doesn't make sense,but my old EDM 85 si had a completely different cast iron header than my 86 US spec one,but ya who knows?
  6. pissedoffsol
    why is this in anything goes? :bash: moving to general tech
