stmotorsports
hey all. I've been planning on adding a rear sway setup from a 4dr civic EX to my '94 EX coupe, but then I found out the 4dr GSR uses a 14mm rear bar instead of the 13mm so I was planning on going with that one instead. I know the GSR bar will bolt right on (with the teg or 4dr EX LCA's), but now I come to find out the '96/'97 vtec del sols use an even bigger 15mm rear bar. The 4dr civic EX/GSR LCA's are the same Honda part, but the vtec del sol LCA's are supposedly different from everything else for some reason. Does anybody know if the 15mm bar will bolt right on? Which LCA's will I need? Thanx for any help
