VTEC solenoid leak
1998prelude1998
I have a 1998 prelude. It has a jdm h22a. I replaced the vtec solenoid gasket because it was leaking from the bottom. It has been about 2 weeks and it is leaking again. I am wondering if the jdm h22a has a different vtec solenoid gasket that the usdm h22a4??????? SOME ONE PLEASE HELP
Did the gaskets look the same when you replaced the old one? If the gasket only just started leaking, I'm guessing they are the same. An incorrect gasket would cause oil to dump out when you build oil pressure. Check the cam seal in that area for leaking too.
