Now that I've had time to work on the ABS I've ran into another problem. My ECU flashes the code for the vtec solinoid valve. It wasn't doing this before. It runs fine when going under half throttle, but as soon as I step on the gas it runs up to about 6 and then just kicks out, the code flashes, and the car starts running like crap. I've check, recheck, and checked again my wiring and it's set up right. I've redone the connections to see if that would fix the problem, but that didnt work. If anyone knows what could be causeing this or any ideas on what do to to keep testing let me know.
