Vtec Solenoid?
Discussion in 'Engine Building' started by xxk0ssxx, Jan 3, 2003.
  1. xxk0ssxx
    xxk0ssxx Junior Member
    ok vtec people where should i connect my vtec solenoid oilpressure line on my mini me setup. should i make a brass "T" right at the line above my oil filter or what is the best way so vtec will actuate? thanks
  2. cws13
    cws13 Senior Member
    Athens,GA
    You need to install a threaded T-fitting into the hole where your oil pressure sending unit goes. Re-install the OPSD in one end and run the line off the other. Get something sturdy. I've see softer metals crack off ond blow oil everywhere. This could cost a motor at high RPM's. Also, determine now if you are going to run a mechanical oil pressure gauge in the car now because you may want to make your splitter with three prongs.
  3. hatchboy
    hatchboy Sleeves+boost=Love
    Oak Harbor/Battle ground,wa
    All the local shops told me that on a mini me (assuming you are using the non vtec ecu and activating vtec via a switch or rpm activation switch) you dont have to run the vtec oil pressure sensors anywhere. I just finished my mini me on my car and hooked vtec up to a switch and it screams. I didnt do anything with the oil pressure sensor on the vtec sylenoid.
