vtec stutters....
91si
pretty simple, vtec used to work good, then one day it doesent.\
b16a into an ef, when vtec hits it hits good for a half a sec, then starts sputtering like its redlining, but only around 45.5k-5k....
Basicly its not engaging fully.
Any ideas...i heard low oil can cause this, but my oil is full...
I added a qt of oil still does it..
Car is fully wamrmed up..
I cleand both solenoid and switch...
It works just cuts in and out.
Sounds like its hitting a rev limter around 5500rpms..
Pissing me off any ideas?
The first thing I thought of was to clean the solenoid and the screen/gasket assembly. I'd replace it. It's unfortunately like $25-30, but it's part of the elimination process... and it can't hurt to do it.
I stated in my first post i cleaned both screens, and solenoid and switch, there is nothing else i can clean.....\
Any more idea?
Tried a different solenoid all together from a different car, to see if it remedy's it?
I dont have a solenoid i can try. But i put a constant 12v to the soleniod and it clicks really fast...so i know it works.
Just put another one on there. Process of elimination, bro.
Junkyard, Friends, Buy one from honda then return it. idk.
