vtec + turbo ????
Discussion in 'HYBRID -> EG-EK / DC' started by dementedman, Nov 3, 2002.
  1. dementedman
    dementedman Junior Member
    Sorry i forgot this .... Is it better having a a non-vtec with turbo or vtec with turbo ????
  2. chet
    chet Senior Member
    st petersburg, florida
    vtec is always better than non-vtec.
    i have yet to see a non-turbo put down hp numbers that vtec motors do.
    its all tuning...and getting the air/fuel ratio correct. i have a friend running a built gsr turbo and with 5psi he's running with ls1's and lt1's from a roll.
    with tuning, ie bigger injectors, he will bump the psi up to 10 and walk the same cars hes running with now.
    i've also seen a b16a here in tampa that put down 406hp to the wheels. vtec is amazing technology...for those claiming turbo is not good with vtec...they're wrong.
  3. D See 2
    D See 2 Senior Member
    Baltimore, MD
    agreed
  4. Havok
    Havok Senior Member
    Florida
    DOHC VTEC B18C1 with 5 psi? wtf? That's what a D15B7 can run.
  5. SolReaver
    SolReaver Senior Member
    whats all this i hear about valve overlap and boost escaping out the combustion chamber because of it (vtec)?
  6. pissedoffsol
    basically, the duration of VTEC cams is open a long time for turbo
    and because of this, you have that overlap.
    it can be solved with a set of turbo cams, and cam gear timing.
    That said, would I ever boost a VTEC?
    if i was filthy rich, owned my own dyno, and was god of honda tuning.
  7. Baker
    Baker Senior Member
    Schaumburg, IL
    ^'m with him valve leak sucks balls
