VTEC = What RPM?
Discussion in 'HYBRID -> ED-EF / DA' started by civic650, Jan 28, 2005.
Thread Status:
Not open for further replies.
  1. civic650
    civic650 Junior Member
    What RPM does VTEC start in a B18C1 (95 GSR) motor?
  2. sihatchback_RL
    sihatchback_RL Senior Member
    4500, with right speed and engine temp.
  3. Riceras
    Riceras Senior Member
    Dallas, Texas
    I am 99% Sure that a GSR VTEC kicks in at 6000-6200 on a stock B18C
  4. phunky.buddha
    Dallas / Fort Worth, TX
    I'm 99% sure that VTEC is set at 4400rpm on a stock B18C1. :p
  5. nfn15037
    nfn15037 Senior Member
    Here is your final 1%, it engages at 4400 RPMs on a stock P72 ECU :p
  6. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    If my mind serves me right which it does every once in a while i believe its 4400.
    I forget about when the secondaries kick in but that was not your question.
  7. StarBellieAngel
    StarBellieAngel Senior Member
    San Jose, CA
    well, i am 1872498273983743% sure it's 4400 on a stock ecu.
  8. phunky.buddha
    Thanks man. I was too lazy to reach for the service manual- even though it's only about 5 feet away from my head. :lol:
  9. civic650
    It is a stock P72-A05 and a stock motor. I don't have a tach so thanks for everyone's help.
  10. spoonsivtecs
    spoonsivtecs Junior Member
    Vtec on my 94 GSR b18c1 engages at 6200, ALL THE TIME EVERYTIME! if your engaging at 4400 check your ecu for a chip, i bought a chip off of ebay that will drop vtec engagement to 4400, and raises redline to 8900
    stock usdm b18c1 vtec 6200rpms and redline is 8200rpms..
    vtec engagement has many variables it goes through b4 engagement.
  11. DelSlo
    DelSlo Senior Member
    no man, im pretty sure it IS 4400.....
  12. aLLmOtOr
    aLLmOtOr Senior Member
    BAY AREA
    I thought it was 4800 then 5200 ... hhahahahahahaa .. variables before Vtec can work? How so?
  13. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Your cam lobes switch over at 4400 rpms. Your secondary butterflys in your intake manifold open at around 6k. That is the sound you hear that you THINK is VTEC. And yes, factors affect the switching of your cam lobes, ie. engine load, temperature, rpm, and oil pressure to name a few. Hope that helps. B)
  14. nfn15037
    Yep, you are wrong! VTEC is @ 4400, the secondary butterflies open at 5700 like everyone has said.
    FWIW, the ECU needs coolant temp, VTEC oil pressure, vehicle speed, and throttle position to engage VTEC. If will decide when or even if to engage VTEC based on those inputs.
  15. jamesA
    Are you sure it wasn't already chipped when you bought the car? Cal, and like 80 other people already told everyone stock VTEC is 4400 rpm... obviously someone messed with your GSR before you bought it.
  16. TeamUrbanChaos
    TeamUrbanChaos Certified H22 Super-tech
    Home Of ThE LoSt Towers
    it is deffiantely 4400....my firends got A 96 GSR and it enages at 4400
  17. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    I will be the 39484358 person to say 4400 rpm,
  18. Hooch
    Hooch New Member
    B18C1
    VTEC Switchover : 4400 rpm
    VTEC Engagement: 5800 Rpm
    common found in 1994-2001 integra GS-R
    hope this helps ya :)
  19. BrutalB83
    Rochester Hills, MI
    This thread is from 4 years ago dude. Please check the dates on stuff before you post from now on...
Thread Status:
