vtec wires
Status
Not open for further replies.
BIGMAN
I had to add the three vtec wires for my engine swap, ive added the three wires to the plugs on the ecu side and ran them through to the motor, the knock sensor and vtec solenoid were easy as i just had to add the pins to my plugs on the stock harness, my problem is that when i came to do the same thing with the oil pressure sensor there isnt a space to add another pin on any of the plugs on my stock harness.the engines a 99 b18c ITR JDM and im using the engine harness that came with the motor so the sensor is wired into the engine harness but surely when i connect the plugs together its not connecting to the right wire.
hope that makes sense :blink:
Do you have a pinout for your ECU? The pinout should show you where your sensor plugs in.
Status
