Vtec wont engage, whats the deal?
Discussion in 'HYBRID -> EG-EK / DC' started by SpoonTuNed, Sep 12, 2005.
  1. SpoonTuNed
    SpoonTuNed Senior Member
    I have a 97 gsr and i just put ctr cams in it and now its throwin a 22 vtec malfunction or something like that. Can this be because of a bad solenoid or pressure switch? I dont know what the deal is cause i tried puting vtec on a button and it still wouldn't engage but i can here the solenoid click. PLEASE HELP I WANT VTEC!!!!!!!
  2. CoreyR
    CoreyR Senior Member
    low oil pressure could be a reason.
  3. SpoonTuNed
    what would cause that? the oil pump is pretty new and i think its good on oil, that would cause it to throw 22 and not the oil light?
  4. CoreyR
    im not sure, i think VTEC needs a certain amount of oil pressure to engage. the solenoid is not actually what activates VTEC oil pressure is what activates it.
    the oil light comes on i think at like 7 psi. code 22 is for the oil pressure switch not the VTEC solenoid. check the wires on the oil pressure switch a quick search on H-T showed people having problems with the wires comming loose on the harness plug for the pressure swtich
  5. SpoonTuNed
    I'll check out the wires, thanks
  6. SpoonTuNed
    would it matter if i dont have the plug fot intake air butterflies hooked up?
  7. CoreyR
    no the IABs are completely seperate from VTEC
  8. SpoonTuNed
    i dont know what the prob is then, sometimes it will hit and sometimes it wont, and when it wont it'll redline at 6700. hella wierd. im gonna try to ground out the press. switch to the block and if that wont work then i dont know.
  9. brian11to1
    brian11to1 Senior Member
    also, go ahead and remove the vtec solenoid and clean the screen.
  10. PhyRe
    PhyRe Senior Member
    ct
  11. SpoonTuNed
    alright thanks, the wiring is all stock though, its a gsr so nothing had to be pinned in. im gonna check it though.
