i just swapped a jdm b16 into my eg. it didnt come with a map sensor so i t-d into a vacuum line and used my d series. my vtec will not work. i check for continuity through the wires to make sure there is not a break. i triple checked to make sure it was wired right. oil level is full and stays there. what could be causing this. also my knock sensor is not wired. would this cause it not to engage?
