tylonalsnifnfool
would it be possible to put a VTEC head on a 1.6L DOHC ZC?
Originally posted by the fool+?-->the fool @ ?) said:would it be possible to put a VTEC head on a 1.6L DOHC ZC?
Unless you really want to play around in the machine shop and cobble things together, no.
Originally posted by endlesszeal@?
i doubt it.. since ZCs are from different castings for the Dseries and Bseries.. correct me if im wrong.
You're wrong. The DOHC ZC is a D series block.
Originally posted by senate_9427@?
Actually the ZC is a D series, but the only VTEC D's are single cam, so it would make more since to go with a D16Y8 or D16Z6, since they are already VTEC.
Originally posted by 91dxSiR@?
sohc vtec head or dohc vtec head?
i know for a fact the dohc vtec head wont work...
Yup- the only DOHC VTEC head for the inline fours is the B, H, and K block heads.
Originally posted by pissedoffsol@?
the ZC is DOHC. you don't need vtec dude....
Not always. There IS a SOHC ZC non-VTEC that's actually stamped ZC from the factory. I have one under the hood of my CRX. It's not a D16Z6 that everyone likes to call a ZC.
Originally posted by cavrx@?
i got a sohc zc could you make this v-tec?
Yes you can. The SOHC ZC is basically a D16A6. The short blocks are definitely identical. I've pulled my SOHC ZC apart and seen the PM6 markings on the pistons. You can drop a SOHC VTEC D16 head on the SOHC ZC and make it a mini-me.
Blanco@?
I don't believe so. But you can buy a D16Z6, SOHC VTEC, for around $3-400. And the Z6 has way more aftermarket backing.
Originally posted by SleEPeR_CRX+?-->SleEPeR_CRX @ ?) said:
good work calesta, u beat me to 'er
:roll: :roll: :roll: :roll: :roll:
Like you would have given the right answers anyway. <_<
Blanco@?
Schveet. I've seen you talk about the A6/Z6 mini-me and building it up. If I remember correctly, something like 12:1 compression and 130-150whp. I'd love to do that, but I live in Cali so I'll just have to swap my A6 out and into my DX
Is it possible to get the same compression and hp numbers from building a Z6 as from the mini-me?
