VTEC ?
Discussion in 'HYBRID -> EG-EK / DC' started by H22 Fan, Jun 5, 2005.
  1. H22 Fan
    H22 Fan Member
    how can i make sure my hatchback is a sohcvtec?
    i cant find anything on the block that says d16z6
    the spark plugs are in front..does that mean its a vtec??
    i have the p28 ecu
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Look for the vtec solenoid.
  3. H22 Fan
    H22 Fan Member
    whats that??
    on the head..it doesn't say VTEC like some of the other Vtec i seen
    but i kno that it doesn't need 2 say vtec in order to b a vtec
  4. xj0hnx
    C.C.TX.
    It looks like this...
  5. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Your hatch should be an Si if you have vtec, unless it's had a swap. Check the stamp on the block next to your tranny. Also, look for your Vtec soleniod. Too easy...
  6. H22 Fan
    H22 Fan Member
    ah
    found it
    the block number was all covered by dirt and it was impossible to find it
    but its a d16z6
    exactly how many horses does it have??
  7. capone9399
    capone9399 Senior Member
    Scranton
    d16z6 has 125hp stock
