VTM on the apexi V-AFC2 HELP
Discussion in 'ECU's, Electronics, and Tuning' started by 3D HONDA, Jul 9, 2006.
  1. 3D HONDA
    3D HONDA Junior Member
    Bonnie Scotland
    Okay folks havehad to disconnect my vtec controller because of the following problems and hope that you guys n gals can help me here
    The controller is wired correctly!!!
    The car falls out of vtec at 6500rpm then hits limiter what could this be ?
    The infamous VTM signal i have wired into the loom were it says it is and the car runs like a bag of nails plus with an engine management light on and eratic idling what could this be as when i disconnect the wire and return it to stock everything is fine other than the vtec fall of at 6500rpm
    plus were the VTM signal wire is the wire from the ecu is blue n white and then 1 plug space down the same colour of wire is there as well could this be the problem ?
    the car has recently had an engine swap to make it a h22a accord and works perfect please please please can someone help me
