vw meets b18
Discussion in 'HYBRID -> EG-EK / DC' started by paulsen, Apr 11, 2010.
  1. paulsen
    paulsen sponge of knowlege
    sac
    im looking at my sand rail that is mostly comprised of vw pan, chassis, and wheels, and thinking to my self, i wonder if i can put a honda power plant in this thing, now i bring the question, does anyone have any foresight on any possible snags or problems that i might encounter? at this point im excited, and hope to stay optimistic, i currently have a 98 ls motor and an old tranny lying around i think i have an ecu and im going to get a harness for the car tomarow, any suspension advice would greatly be appretiated because im clue less in this department
  2. efhondakid
    Akron-Canton, Ohio
    They make an adapter plate to mate the B-series to the VW trans, you have to change something in the VW gear box because the Honda motor spins the other way.
  3. paulsen
    sac
    i heard some stuff about the adapter plates, mostly bad news, what i heard was you can adapt it, but also have to flip the ring gear 180 degrees, in order for it to rotate correctly, but fliping the ring gear only weakens the tranny limits, to an already weak tranny, i have so far all wiring harness from the swap motor and tranny, all smog equipment pretty much everything down to airbags and cc, im thinking of an all honda swap, but dont know how much the stock suspension will allow for travel, and if im over looking any minor deatails that can be crucial in the end game
  4. paulsen
    sac
    but thank you for any information, sometimes there are deatails over looked?
  5. efhondakid
    Akron-Canton, Ohio
    My boss has a 300hp STi motor in his sand car with an adapter plate to a stock 6-rib bus trans. I would keep the VW trans, use a 3-rib bus trans, or if you have the money the big bad 6-rib. Its going to be hard to get the Honda tranny to mount the VW frame horns.
  6. paulsen
    sac
    yeah im not sure what those run but i hear that they can handle some torque, i wasnt emplying that they are not strong tranny but the one in my rail is rated 100 hp 150 max, i was just thinking for a little bit better realiability since illl be running 150 hp, and im not sure but do you think that they would be able to handle high rpms? any suggestions on mounting the honda tranny? i have a welder and can get some tubing for a "sub frame" if you would call it that,
  7. efhondakid
    Akron-Canton, Ohio
    Its going to involve too much work to get the honda tranny to work, its just not worth the hassle, look around for a 3-rib, youll thank yourself later for running the vw trans axle.
  8. 78civic
    78civic Junior Member
    NW MS, Y'all
    I'll sell ya some Buick V-6's..? 3.8/4.1
    OR if you want, How bout a Olds 215 aluminum V-8. I gots two.
    E
  9. paulsen
    sac
    what would the honda tranny involve, because i have never flipped a ring gear in a vw tranny. and im not to sure about trying to get the tranny to work in the right direction
  10. eg6sir
    fixed ur title
  11. paulsen
    sac
    no thanks im trying for a budget build, and there is no room for a motor purchase. but thank you for the offer
  12. paulsen
    sac
  13. paulsen
    sac
  14. efhondakid
    Akron-Canton, Ohio
    Im not sure what exactly what is involved but from what Ive heard its pretty simple to do. A google search should come up with some good info.
  15. efhondakid
    Akron-Canton, Ohio
  16. eg6sir
    haha.. you can hear it
  17. paulsen
    sac
    very nice video, i think thats awesome, makes me wana get a bug almost, haha, does anyone know where i can get a clutch allighnment tool, without buying a clutch of course?
  18. paulsen
    sac
    i love the grand stands on the video, what do we call that here? isnt that a ditch
  19. paulsen
    sac
    if i was to couple the motor to the vw tranny i think my rail would be really heavy out back causing a major wheeelie problem, dont get me wrong i love a good wheeelie but im not sure how the racing aspect would be affected
  20. efhondakid
    Akron-Canton, Ohio
    Thats what cutting brakes are for, even with the front wheels in the air you can still steer.
    YouTube - Circle wheelies in a dune buggy
