VW turbos
Discussion in 'Forced Induction' started by 92civicb18b1, Oct 16, 2003.
  1. 92civicb18b1
    92civicb18b1 The Trisexual
    What do you guys think of VW/Audi turbos. And if I bought one could I buy a T3 manifold, and a T3 flange and weld it on to the VW/Audi flange. Or would i have to get a custom manifold.
  2. CRX_B16B
    CRX_B16B Senior Member
    it would probly be better to reverse that buy a VW/AUDI flange and turbo and weld the flange to a T3 hedder cuz cast iron doesnt weld very good.
  3. 92civicb18b1
    I see your point, do you know where I can buy a VW/Audi flange?
  4. 92civicb18b1
    O I forgot now I have a couple of other questions?
    I have a LS, planning to turbo it at about 8 psi, looking to get at least 250 whp on stock internals, will I still need injectors and pump, or am I good to go with an intercooler, piping, BOV, manifold, FMU and turbo. Also should I buy hondata for tuning?Will this make it so I won't need to buy an FMU?
    Also what would you expect my 1/4 times to be with this set up? It will all be custom.
  5. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    i bet your times will be faster than they are right now... maybe....
    if you go with hondata you will not need an FMU, you will however need bigger injectors if you really want to reach 250 whp. you should also consider buying the boost option w/ hondata.
  6. CRX_B16B
    if you have a V-dub turbo already you could have a machine shop fabricate one out of a 3/4" steel block I dont know if they would want to tho you would have to ask them
  7. 92civicb18b1
    I think I'll probably be better off trying to weld a T3 flange on the turbo itself. Im sure it will be able to hold 8 psi.
  8. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    turbo's have manifolds.
    its header, not hedder.
  9. CRX_B16B
    good I'm not late for class the grammar teacher got here after me, thank god we can't have bad fuckin grammar what would we do with out you. <_<
  10. CRX_B16B
  11. NoJokE
    NoJokE Senior Member
  12. convertedstangbanger
    convertedstangbanger Senior Member
    ATX!
  13. 9k RPM EG6
    9k RPM EG6 Junior Member
    originally: Napa, CA now: Phoeniz, AZ (for school)
    or save a couple bucks and don't buy the shitty little VW turbo. The little K03 they run is hardly worth the metal used to manufacturer it. Buy a t03/t04E (same as T3/T4hybrid, but 3 inch compressor inlet as opposed to 2.5). Then show some VW what the f**k is up!
    -Brian
  14. 92civicb18b1
    hahaha, I went out and bought a t3 last week, VW turbos arent worth the money but for what i paid ($50), it wasnt wasted, I'll give it to a friend with a hyundai elantra, he defenitly could use it.
