walbro fuel pump install
Discussion in 'General Tech and Maintenance' started by preludebuddy, May 25, 2005.
  1. preludebuddy
    preludebuddy Senior Member
    putting the rad in colorado
    i just installed my walbro fuel pump, which was an absolute disaster btw. anyway its in and its working but my fuel pressure jumped almost 8 psi at idle. it was at 42ish, now its at about 50. i have an aem fuel pressure regulator, just havent installed it yet. do i need to install it and get the fuel pressure back down or is 50 psi okay for a gsr motor? reason i'm asking is because i want to sell the fpr if i dont need it so i can buy other things for my turbo project.
  2. ripperbone
    ripperbone angry bear
    Oklahoma
    i would keep the regulator, install it and see what the reading is at, and if needed then adjust the pressure down
  3. preludebuddy
    thanks for the input. i'll probably just install it tomorrow. what is the ideal fuel pressure for a gsr then?
  4. ripperbone
    Oklahoma
    im not sure about that, if its different than the b16 or not.
    I have my b16 at 30 psi at idle and when you hit the throttle it spikes to 40. my set up is set for stock pressure. I would think that your setup should be the same.
  5. bgpmpn
    bgpmpn New Member
    my gsr has a stock fuel regulator and its running at 41lbs and 51lbs when you hit the gas
  6. Justin91civic
    Justin91civic New Member
    Nashville, Tn
    Do you realize that this thread is over 3 years old!
