crxlsvtec1221
Member
I just bought a usdm 94 gsr motor putting it into my 92 vx shell and I just need some ideas on how to make around 250 hp with only stock internals if thats possible. Money is not an option
Originally posted by crxlsvtec1221@Jan 5 2005, 08:03 PM
should i at least do up the block alil for nitrous, and I want some type of setup that is more permanent
[post=441677]Quoted post[/post]
Originally posted by 99SiRidinLow@Jan 6 2005, 11:50 AM
How much money? High compression, agressive cams, good air flow, and giggle juice. Also stroking it will help quite a bit too. So all honda.... ITR crank, rods, CTR pistons, ITR intake mani, itr header, get your head port & polish Only way to stay all honda and get 250 is with nitrous.. Also do you want 250whp or to the crank or you could opt for the ls crank and rods wit ctr pistons
[post=442001]Quoted post[/post]
