WANTED B16 DIST
fastintegra
I need a b16 distributar preferebly not working cause im only going to strip the guts out of it i did a swap in my 92 teg and i couldnt use the b16 dist because its obdo so i had to use the ls dist but the bolt patterns are different so i had to cut the legs of the ls dist and now theres only one bolt holding it on thus now i have an oil leak so i tried using the b16 dist i had and the little bolts holding the guts in snapped off inside there hole and its benn a night mare so now i need another one to try again.
