wanting to lower the del sol
Discussion in 'Wheels / Suspension / Tires / Brakes' started by redneck999, Jul 8, 2009.
  1. redneck999
    redneck999 Member
    Oakwood Il
    If i lower it say 1.5 will i need a camber kit or is this some thing that can be adj with an alignment? Would anything else be needed besides strut/coils?
  2. turbod eclipse
    turbod eclipse New Member
    you could simply just buy some coilovers and it'l drop. and be adjustable 2-3" up and down. they are nice to have when you want to be low...and even better when you want to raise back up. you'll most likly need a camber kit...but as far as a 1.5 drop. you should be fine with the camber kit.
  3. 95b16coupe
    95b16coupe New Member
    ct
    you can get some good springs for that amount. you dont' really need coils if you aren't going to adjust them.
  4. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    you shouldnt need a camber kit with a 1.5" drop. just get some nice springs and shocks, it will be like a whole new car.
  5. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  6. E_SolSi
    adjustable coilovers are not so you can keep raising your car up and down... they are so you can corner balance your car
    if you are not going to corner balance your car, get springs you will be better off
    1 person likes this.
  7. Fernpatch
    Fernpatch Member
    Bellingham,WA
    word. + rep for giving good advice
  8. redneck999
    redneck999 Member
    Oakwood Il
    Yeah no fancy adjusting, just going with straight lowering coils, its just a daily driver, no racing or anything. Thanks for the advice! Didnt want to have to make multiple orders if i didnt have too.
  9. E_SolSi
    and no you do not need a camber kit for a 1.5" drop
  10. 95b16coupe
    ct
    but yes, you should get an alignment afterwards.
  11. E_SolSi
    absolutely
    you should get an alignment after fucking with any suspension components
  12. redneck999
    redneck999 Member
    Oakwood Il
    Dont want to give summit anymore money than neccesary.
  13. redneck999
    redneck999 Member
    Oakwood Il
    Just curious, is there a difference between the front and rear springs? The sol has always sat a bit lower in the back compared to the front.
  14. FLounder
    yes the front and rear springs are different. they have different rates. im sure after you install all new springs and shocks the car will sit nice and level. your old suspension is probably well worn.
  15. E_SolSi
  16. redneck999
    redneck999 Member
    Oakwood Il
    I am deff hoping so. didnt want to have to order diff size drop for front and rear., easier to to just order a set.
  17. redneck999
    redneck999 Member
    Oakwood Il
    Just ordered the Eibach pro kit spring set front and rear! And so it begins. Woo Hoo!
  18. E_SolSi
    what shocks are you running with them?
  19. redneck999
    redneck999 Member
    Oakwood Il
    I am going to run the stock ones for right now. Last week i ordered a set of new strut mounts and are in the process of extending them, that way i will still have original springs and mounts if i ever need them.
  20. redneck999
    redneck999 Member
    Oakwood Il
    I am also wondering if i should only do the front and wait on the rears, right now i have 3 in gap top of tire to wheel well in front and 2 in on the rear. If i just do the front it would be level and if i did the rear and the original coils had sagged then it would be setting too high in the back?
