Warped Rotors
Discussion in 'Members' Lounge' started by reckedracing, Nov 23, 2015.
  1. reckedracing
    reckedracing TTIWWOP VIP
    NY
    Just going to put this article here for right now.
    We've all heard about the warped brake rotors and brake pedal pulsation.
    This article lays out some things that might cause premature brake failure.
    I found it while doing some research on the subject and this seems to really make sense to me.
    http://www.hendonpub.com/resources/article_archive/results/details?id=1787
    Opinions?
    I don't typically torque my wheels on re-installation, but i also have a Tacoma that seems to need new rotors every 9-12 months. Going to give this a try and see what happens.
    Assuming discount tire.com torque information is accurate honda and toyots only call for 80 ft lbs of torque on wheels studs. somethings tells me my breaker bar is way too much leverage for this application.
  2. E_SolSi
    always torque wheels on
    Dual-500 likes this.
  3. chestercheeto48
    chestercheeto48 Senior Member VIP
    madison, WI
    I (and my students) use torque sticks to torque our lugs back on when appropriate. If we don't have a stick that fits the recommendation then we use and actual wrench. The interesting thing to me was the fact that people don't use the star pattern and simply go in a circle after being hand tight.
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Torque wrench, every time. Every time. EVERY time.
    Dual-500, BigJ and reckedracing like this.
  5. civicious
    Houston, TX
    ...or, alternatively, three gachookas with the impact.
  6. E_SolSi
    i was always taught the correct spec for anything is to torque it down til it breaks/strips then back it off about 1/4 turn
    CAFROG and civicious like this.
  7. E_SolSi
    or just lean in to the impact gun pulling the trigger in short bursts while yelling "Get some!!!" (ala: Full Metal Jacket) like like some kind of short bus door gunner
    CAFROG, Dual-500 and TurboMirage like this.
  8. tab
    tab Super Moderator
    Aberdeen, Washington State
    My 1/2 inch impact has several settings. The low setting is perfect for torquing a normal wheel/tire. I do use a star pattern. I partially tighten in sequence, then go back around for full torque in sequence. Never a circle.
