Washer fluid
Jazzy19
i have a 93 SI n the washer fluid wont come out... I cant hear the motor making noise??? is this my motor gone.... If so how much do they cost n how hard are they to replace....Could it also be that the fluid is frozen or the hoses r clamped too tight....
thanks in advance
If I were you I would disconnect the washer hoses right after the pump, and see if water comes out, that way you know whether you have a cloged hose or if there is something wrong with the pump. As far as the price for a new pump check out hondaautomotiveparts.com or check around at junk yards.
I'm having the same problem wiht my 00 Si. I ran out of fluid and filled it up yesterday, still nothing comes out. I'm a take a look at it in a bit.
thats the same thing that happen!!!! What is causing this
let me know if u find out...im gonna check it out also
take one of those vaccum pumps and put alittle bit of water in the hose and pump it up through the nozzle manually. Just a idea to see if its just cloged.
