wastegate install
Discussion in 'Forced Induction' started by zap45, Mar 16, 2009.
  1. zap45
    zap45 New Member
    albuquerque nm
    i plan using a mbc with my turbo setup which has external wastegate i saw several ways of hooking it up. Here is a couple of ways of hooking it.
    But on top of the waste is block off in one of the picture how would i hook mine wastegate with the boost controller
  2. Briansol
    top goes to the boost controller
    side goes to a vac source direct.
    thats all that needs to be done.
    if the top of your WG is blocked off, you might have to contact the dealer/parts guy for the piece that it needs.
    what brand is it? looks like a tial...
    you just gotta get the right fitting.
    the source (in this case, fittin on the turbo) can be from anywhere. vacuum is vaccum.
  3. zap45
    zap45 New Member
    albuquerque nm
    which pic is correct?
  4. Matts96HB
    Matts96HB . Moderator VIP
    Read what B said, he's exactly right.
  5. TurboRex90
    TurboRex90 Golden EG
    Maryland
