wastegate mounting question
spdr
Member
A buddy of mine is putting together his turbo setup and he just has an ssautochrome manifold and even though its cheap its all he can really afford. the car this is all going into is a crx with a b18 so where the wastegate outlet is on the manifold it is almost running right into the half radiator. so the question is can an elbow be put on the outlet to turn the wastegate to a different angle so it avoids the radiator? or should he just look into getting a different manifold altogether, if its too much hassle and all that...
there are elbow flanges availble on the net. its fine to use.
the manifold is shit, however. i suggest you brace it somehow, because 90% of the crack.
