Ignorant import guy
Alright so this is a noob question; should the port on the wastegate be bigger than the port on the manifold. I have a cast iron manifold which is supposed to hold a 38mm wastegate (which I bought) and the port on the wastegate is about 2-5mm bigger than the manifold port. Is this the way it should be?
