HellBentHONDA
ok this should be quick.
when using a manual boost controller with an external wastegate, does it matter what size spring is in the WG? obviously it shouldnt be higher than the set boost on the mbc but im guessing it should be as small as poss to prevent spiking and allow the WG to open ASAP :roll:
dont respond if you think you know. would prefer people that know for sure.
