water leak
roman_pushkin
why is my trunk leaking in a 90 accord ex? Is this a common problem for this type of year? Any way to fix it?
The tail light gaskets are a common spot for leaks.. I sealed mine with silicone on both sides of the foam gasket and it fixed it.
If you have a sunroof there are drain tubes in the trunk on the side, underneath the plastic panels, that sometimes become clogged up and leak into the trunk as well.
