water temp gauge
Discussion in 'Civic and CRX - EF' started by desert-storm CRX, Mar 6, 2008.
  1. desert-storm CRX
    desert-storm CRX New Member
    winston salem nc
    i'm trying to put in a water temp gauge in my 90 civic si and i cant find where the hose bolts in at....does anyone know where to do this at?
  2. get_nick
    Washington State
    just out of curiosity, why are you installing a water temp gauge? if it is a stock car, it will only draw people to thinking it is worth stealing.
  3. maykelcj
    maykelcj New Member
    :lolhammer:
  4. desert-storm CRX
    winston salem nc
    well i'm slowly working to build it so i'm trying to start small and go big.....i try not to go too big too fast after i messed up my crx's wiring
  5. GlassHeadlights
    Calgary, AB
    why would you put another gauge in if there is a perfectally good one already in the gauge cluster?
  6. desert-storm CRX
    winston salem nc
    because i came with the cluster an i figured it would look pretty dumb to have 2 gauges in a 3 gauge cluster
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    its either on one of the waternecks or the side of the head i believe,,
  8. xXxcaoticxXx
    xXxcaoticxXx ©aotic-©reations
    killeen texas
    kinda funny how people ask questions to only get flack....i havent installed mine yet if i ind the hole i will let you know man.... some people get rid of there gauge clusters and go to all gauges so it makes sence to use one....
  9. BrutalB83
    Rochester Hills, MI
    Understandable, but do you really need a water temp gauge? Unless you're motor's built and/or boosted, then a bunch of auxiliary gauges really aren't necessary, and like others said, they give thieves a reason to think your car might be worth jacking.
    Rather than just spending money on random gauges, a better idea would be to plan out exactly what you want to accomplish with your car, and then start working towards that.
  10. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Just let him rice it out. He will learn eventually. If that is what he likes and it makes him happy, fuck it. We all had our days, let him have his.
    As for where you would mount the hose, it usually gets mounted somewhere near the water-neck outlet near the thermostat. It also depends on if it came with an adapter or not but it should usually feed from the upper radiator hose area near the engine block.
