it won't give you a CEL - there is no CEL code for the water temperature gauge - the engine coolant temp code 6 is code for the sensor for the ECU - it is the other sensor on the end of the head with 2-wire connector - what kind of gauge is it?Quoted post[/post]]
there has got to be way around it.. .. it will just give me a CEL right?? i just had my car smogged so that doesnt matter, i can always switch it back if needed
came with sending unit, correct? you need Autometer Part No. 2268 metric adapter which screws into the head in place of the OEM sensor and the Autometer sending unit screws into it - the sending unit won't screw directly into head because of different thread size - i have installed many of these and you won't get CELQuoted post[/post]]
its an Autometer Pro comp ultra light..
Quoted post[/post]]
Autometer gauges will not work with the OEM sending unit - this is quote from Autometer:Quoted post[/post]]
Quoted post[/post]]
Or you can do it the easy way.
Strip 1.5inches of the wire, stick it into the little black single connector, plug it back in... yay.
My Faze gauge said the same thing so i tried it anyways... works fine?Quoted post[/post]]
Quoted post[/post]]
"Electrical temperature and pressure gauges require the use of a sender matched for the type of gauge in use; the stock sender will only work with the stock gauges. Auto Meter gauges are designed to work with the Auto Meter sender that is included with the gauge."
Mine was broken, so i asked here.Quoted post[/post]]
if you disconnect your stock gauge do you know what normal engine temperture is for your motor?
my stock gauge is broken.. the needle broke off. ..Quoted post[/post]]
