update lol
well recently i upgraded some hardware and figured it was time to upgrade and expand my loop a little. like many people i bought a RF case when they were cheap, only paid 50 bucks for it so i had no problems cutting it all up. and with a case as huge as the RF case, i wanted to have everything internal.
so i started out with a MCR320 up top like most people do and with an MCP350 pump w/ petras top it was cooling my CPU and 8800GT just fine. well i picked up a GTX 280 and figured i'd expand my loop a bit to account for the extra heat. so in came a Laing D5 pump and an MCR220 rad but there wasnt a good place for it stock. so i decided to cut out a hole for it in the bottom. i had to remove the 3.5" bays but oh well, i wasnt using them anyway. i also had to cut the floor out of the 5.25" bays as the rad was too tall with the tubing fittings. again its no big deal to lose 1 5.25" bay.
i spent a good deal of time thinking out placement and parts. the GTX 280 has the Dtek unisink and the GFX2 waterblock (recycled form the 8800GT). this is a great combo, and ive very happy with the looks and functionality. i also decided to use 38mm 2000 RPM Scithe fans on the 220 not only for better cooling, but also to help even out the airflow since i have 4 relatively low CFM fans pulling air out. case pressure is probably slightly negative. i also used 7/16" tubing and it was a PITA to install but i found using some hand soap as lube helped alot, especially on the plastic fittings. i probably didnt even need the zip ties with how tight everything was, but it made me feel better having them, im even missing a couple lol.
here's some pics. let me know what you think! (yes i know wires are messy but its the best i could do with this case and the amount of components installed, although it could be worse)
i get about P13000 3DMark vantage score (is that good?)
enjoy. and
