WeatherTech Side Window Deflectors Available At CorSport
Discussion in 'CorSport' started by CorSport, Aug 24, 2011.
  1. CorSport
    CorSport Member
    [​IMG] [​IMG] [​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    WeatherTech® Side Window Deflectors offer you fresh air enjoyment with an original equipment look. They are crafted in Germany from the finest 3mm lightly-tinted acrylic material available. Installation is quick and easy, with no exterior tape needed. WeatherTech® Side Window Deflectors are precision-machined to perfectly fit your vehicle. These low profile window deflectors help to reduce wind noise and allow interior heat to escape. Also available in dark tint for most vehicles.
    • Maximize your fresh air enjoyment.
    • Optically transparent.
    • OEM quality.
    • Sleek aerodynamic styling.
    • Reduces wind noise.
    • Installs inside the window channel.
    • No unsightly exterior tape.
    • Minimizes interior heat when parked.
    • Helps keep side windows dry in the rain
    WeatherTech® Side Window Deflectors are guaranteed against faulty materials and workmanship for a period of three years from the date of purchase. Exclusions to this warranty are wear through due to severe abrasive conditions, chemical contamination, such as spilled gasoline, bleach, etc. We are reasonable people and we believe in customer satisfaction. Depending on the situation, we will either replace your product at no charge or charge you a prorated amount for a replacement.ys included in the price you see inside the 48 lower United States.
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
  3. CorSport
    CorSport Member
  4. CorSport
    CorSport Member
    1996-2000 Honda Civic Coupe WeatherTech Side Window Deflectors (Vent Visors) Light $62.00
  5. CorSport
    CorSport Member
    92-95 Civic Coupe WeatherTech Side Window Deflectors (Light)
    [​IMG][​IMG][​IMG]
    OEM quality.
    Reduces wind noise.
    CorSport USA.
  6. CorSport
    CorSport Member
    WeatherTech protects against the elements!
  7. CorSport
    CorSport Member
