Weight Question's
Splat
Hi all, first time posting so please be easy on me.
Iv looked all over for these questions and came up with nothing, so i thought ill give this a shot.
My question is....How much does the V6 3.5 Honda Pilot motor weigh?
And how much does the 6 speed Type S TL trans weigh?
Thanks for any help.
The V6 is probably going to be about 490lbs(I'm assuming that is without the transmission; as thats about the weight of a K20A+transmission).. The transmission should be about 100lb..
The J30A1 only weighed 250 pounds... The J30A4 (+40hp) weighed 20 pounds less than that..
The J35 is a variant of that motor, so I can't immagine it gaining 240 pounds, or doubling in weight by adding a half liter of displacement.
Don't be an asshat.
I actually got my numbers from a C30; which should be a little heavier than the J-series but not by that much. If it's indeed around 250lbs, its much lighter than some of the 4-cylinders; I believe that's about how much the D15s weigh.
Also, I should note that the numbers I'm using are "dressed" blocks; has intake manifold, alternator, etc.
