Weight Removal
Discussion in 'General Tech and Maintenance' started by h22a_in_a_si, Sep 25, 2003.
  1. h22a_in_a_si
    h22a_in_a_si Junior Member
    I have began the insane process of removing the sound deadening tar from my interior. I am using a heat gun and a putty knife. How do I get the remaining layer of goop off so its clean metal? Any tips from the pros?
  2. B16
    B16 Super Moderator VIP
    yay area, CA
    dry ice, then chisle
  3. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    i just left it, once u get into it ull notice that it is damn hard, and tehre are some parts that wont come off at all, so instead of worring to much just leave it. if u REALLY want it off,get it really hot, and use razor to get it off.
  4. Tonyd0821
    Tonyd0821 Banned
    how much weight will you loose if you take the tar off?
  5. h22a_in_a_si
    Can't be much. I've read about tegs or hatches or something having like 15-20lbs, but I'm ony taking the rear half of my car's tar out. I want a metal lookin interior so I can paint it. Plus I like the noise in my cabbin believe it or not! Dry ice sounds like the way to go. Thanx
  6. tab
    tab Super Moderator
    Aberdeen, Washington State
    Do it the hard way. Either you'll lost twenty pounds or the car will. Maybe both. :bo:
  7. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    use some sort of solvent, like laquer thinner-sp? goo gone possibly mineral spirits, etc.
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    use an air chisel and a large flat bit
  9. rudeludenotmeanthough
    rudeludenotmeanthough Senior Member
    goof off, or goo gone... probably the easiest, and least work
