Quoted post[/post]]
set your idle PROPERLY. Most people think that adjusting the idle set screw while the engine is running does the trick. It doesn't. The IACV compensates for whatever changes you make while the car is running. Follow these steps...
1. Turn on car and get to operating temp...
2. Turn car off...
3. Unplug IACV and start car...
4. Adjust idle screw until engine is idling at 700 rpm...
5. Shut the engine down...
6. Reconnect IACV...
7. Reset ECU...
8. Start car up to make sure everything's okay.
If everything in your idle conrol system is functioning properly, that will cure the problem. That's pretty much straight out of the manual. I've done it so many times, it's kinda like second nature. Try that and if it doen't help. I'd say you have a vacuum leak somewhere. Also, double check the voltage on you TPS sensor, with the key in the "ON" position, the middle wire should read .5 volts at fully closed throttle and 4.5 volts at WOT.
