B16 in an EG, sometimes when I start my car, it makes a sound (you know the sound, when you start the car when it is already on). What is this and how do I fix it? Thanks.
given what you told us. Im with knowlege. i had a similar problem with a accord i once owned. And it turned out my flywheel teeth were chewed and it screwed my starter in the meantime. Did you just have your starter replaced?? Make sure it is in straight and secure.
i had this problem too, it turned out to be some bad teeth on the starter, but the flywheel was still fine. replaced the starter and the noise never came back.
What I say yo! Just check the teeth on both! Chances are if one is tore up that bad then its messin up the other teeth!
