Weird Stuff!
civicspeed
sometimes, completely randomly it seems, i start to drive i put it into 1st and start to accelerate and i get hardly any response, the car sorta sputters like its going to die then it acts normally again. this happens rarely but its very odd and i would like to know what the problem is.
also often times i accelerate through 1st and shift to 2nd and start to accelerate and the car accelerates for a little bit then sorta flatens out then accelerates a bit more then flattens off and it does this through the lower rpms or 2nd gear. whats wrong?!?
Its ur plug wires. they are shorting out to the block somewhere....try this....leave the car running and pull each wire off one at a time and see if the motor doesnt change at all when u pull one off
Let me know what you find out.
o my bad i meant one of ur injectors can b loose
