Weird ticking noise when cold
Discussion in 'Accord' started by Skiefer, Sep 20, 2006.
  1. Skiefer
    Skiefer New Member
    Louisville, Ky
    When I first start my car and drive, my engine makes a weird ticking noise that speeds up as my rpms rise. After the car is running for some time the noise goes away. Does anyone know what this is or how to fix it. Should I be alarmed?
  2. TurboMirage
    no alarm. adjust your valves.
  3. eg6sir
    :withstupid: go get a valve adjustment.. i need to get another..
  4. Skiefer
    Skiefer New Member
    Louisville, Ky
    Adjust my valves? What does that mean? Sorry if I sound like an idiot but I don't really know what that means? Can you explain what it means and how to do it? Also what would cause the valves to need adjusted? Would poorly adjusted valves cause the car to tick only when first starting or when cold? Can you explain why it does it? I am not questioning you, I am just curious and have a thirst for knowledge. I appreciate any help I get.
  5. TurboMirage
    yes, poorly adjusted valves tick when the car is cold.
    bring it to the dealer.
  6. Skiefer
    Skiefer New Member
    Louisville, Ky
    Is that something that costs alot of money to repair? Will it damage the engine?
  7. TurboMirage
    no.no.
    i can adjust the valves on my mirage (pretty much same setup as a d15b2) in ~10 minutes.
  8. Skiefer
    Skiefer New Member
    Louisville, Ky
    hey turbomirage, how come you recommend me getting my valves adjusted yet in another forum you said it didn't help you?
  9. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Not sure if you've ever seen inside a motor Skiefer but theres a lot going on. A LOT of metal on metal parts moving. Adjusting the valves takes less then a hlaf hour and is relatively easy to try. Its a start :)
    Has it been awhile since you changed the oil? Have you been driving it harder since the last oil change?
  10. TurboMirage
    sure. my car used to have hydrolic self adjusting valves.
    now that i have my new head on and the valves are adjusted a bit loose, they are vocal. when i tighten them up this weekend the noise will go away.
  11. TurboMirage
    since you probably have no idea what it looks like under the valve cover, here you go.
  12. Skiefer
    Skiefer New Member
    Louisville, Ky
    I changed the oil on my car about 1000 miles ago. But yeah I generally drive the car pretty hard.
