Welp....some relief...I made some boost!!!!!!
92civicb18b1
The Trisexual
After this rebuild I'll actually make real boost.
Anyway, I make 2-3 lbs at like 6000 rpm with the wastegate disconnected and a rediculous amount of smoke. Not exactly functional but its a good sign.
At least it's semi fast (not really, just a lot better) even though I can't really make boost legally after 2nd gear with the LS trans.
[post=495204]Quoted post[/post]​
You got your rebuild kit already? wow....That was fast.... <_<
nah, in the other thread I said I was going to take it off and tighten everything up....I did but it still has a leak and the seals leak oil kinda bad
[post=495232]Quoted post[/post]​
Oh Ok,....Dummy 'me'!
R U running Uberdata yet with your setup? Just curious.... :)
Good Luck! :)
yep...
It's still on a basemap. I have to at least build 6-8 lbs without any type of leaks before I'm going to get it tuned
def man.. work out the bugs first...
BUT- it COULD be your basemap. keep that in mind.
mine from HONDATA was FUCKED beyond belief.
yea...well I'm going to rebuild it first and see what happens. If I still doesn't build the boost I'll bring it to the shop thats going to tune it and he'll modify my basemap.
It felt so nice making some boost. :driver:
seriously man, at idel, i was in the 15 psi boost table according to the real-time map trace. removed the 3-bar, and tried the oem map, and it was still all over the place.
started over from scratch.
Yea, I suppose I could get a different basemap to work with.
If I give him a .BIN he'll burn it for me including the chip for like 10 bucks. I still have to rebuild the turbo and the kit should be here on friday or saturday.
If I still have problems after the rebuild, I'll look into the tuning portion.
