all the u-pull-it yards around here have forklifts or bobcats to help pull engines.
88-91 civics are the easiest to remove as long as you can get underneath the car.
the trickiest part is getting the retaining pin out of the shift linkage.
everything else is straightforward.
take the engine and trans out together.
take the fuel line off at the firewall.
unplug the wire harness on the fender.
9 bolts,1 pin, and fuel line and wires shouldnt take more than an 1.5 hours with hand tools .
2 bolts for the battery tray.
2 bolts for the exhaust manifold.
1 bolt and the retaine=ing pin for the shift linkage.
4 motor mount bolts, and if I remember correctly the front and rear both have nuts on them, (really long bolts too) so you need a wrench for them too.
you will need a crowbar or bigger flat screwdriver to pop out the axles.
#1 rule is dont cut anything! you never know what you will need later so remove it right.
oops, I forgot, remove the radiator hoses.
