What A/C bracket do I need?
3.8turbo
I have a 95 Integra running a SOHC Vtec engine. What a/c bracket do i need to run the 95 A/C system (compressor.)
:ph34r:
:):: Before you ask. Its FL's fastest SOHC Integra! 12.80 @ 109 mph :::)
Pretty easy ....with the exception of all the rain that kept delaying things.
Anyone know what bracket i need?
FL huh, if your living down south never heard of yeah, but good times with the socher..
I would assume the d16 AC bracket that should come with the motor, if it doesn't fit you can get the mount part cut off that attaches to the front chassis (if it even does, sorry no experience with sohc's - only dohc's :)
I am using the SOHC bracket with the stock integra compressor. May end up using a D-series compressor to get the a/c working.
