what amp can i use
LsB16CrxHF
im not into audio...but i got a car that has MB quart component speakers JL mids and no amps....the guy does not know what was in the car before because he didnt install it and the sub and amps got jacked...his speakers were powered off an amp so i take it i need a 4channel amp or a 2 channel bridged to run it....but what do i get...the mb quarts are rated at 60-130 and iduno what the jls are rated at...so would like a 200x4 amp work well enough....i have the sub and amp figured out its just he had two amps with one powering speakers
a GOOD 75x4 will work fine
a decent 100x4 will be good to
definatly get a 4 channel though
200x4 will be quite expensive for a good one and it will be overkill
ill sell you my 350x2 for 150 shipped.
