What are these things?
Discussion in 'General Tech and Maintenance' started by badbreedchiney, Nov 10, 2009.
  1. badbreedchiney
    badbreedchiney New Member
    1990 Honda Civic Dx
    DB6 SOHC ZC Engine
    Wanna know what this rotting/rusting thing is at the back of my car, just need the name of it. I'm looking to replace seen as it has broken on me once before and i had to weld it back and it looks like it will break again any day now in a different spot.
    I tried to outline it so here goes.
    http://i693.photobucket.com/albums/vv296/badbreedchiney/5.jpg
    http://i693.photobucket.com/albums/vv296/badbreedchiney/4.jpg
    Ok thats 1 down. Next thing i want to know is what is this tube i had to plug with a gold screw so air would stop escaping from my intake manifold? Is there suppose to be something blocking it off like what the screw is doing now or is there suppose to be another tube leading from it and connected else where. Any help will be appreciated.
    Once again i tried to outline/circle it so here goes:
    http://i693.photobucket.com/albums/vv296/badbreedchiney/3.jpg
    http://i693.photobucket.com/albums/vv296/badbreedchiney/2-1.jpg
    http://i693.photobucket.com/albums/vv296/badbreedchiney/1.jpg
  2. BrutalB83
    Rochester Hills, MI
    The thing underneath your car is the rear subframe. Not sure about the other question...
  3. badbreedchiney
  4. rkwoos12
    rkwoos12 New Member
    Kentucky
    purge valve i think is the answer to your number 2 question
  5. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    For your second question, if there's no sensor on any of the intake manifold runners, then it looks to be your IAT Sensor.
    1 person likes this.
  6. rkwoos12
    rkwoos12 New Member
    Kentucky
    i like that answer i think its correct
  7. 91civisedaner
    91civisedaner Senior Citizen
    oregon city or
    :D:Dyou need to clean that engine bay!!!:D:D
  8. badbreedchiney
    thanks guys. going to research IAT sensor now. yes the engine bay needs to be cleaned very badly...you should see the rest of the car lol. body work and spray needed
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    The IAT sensor wouldn't be run like that... I don't think.. What motor is this?
    From the way it looks, it sort of kind of looks like a purge cut off solenoid valve.. Does that line run to your charcoal canister?
  10. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    phyregod is correct
  11. badbreedchiney
    i have no idea what you just said sooo yeahh...
