what are they and where do they go..(sensors, plugs)
Discussion in 'HYBRID -> EG-EK / DC' started by hmglauj, Apr 16, 2006.
  1. hmglauj
    hmglauj Junior Member
    says map sensor and has a vacuum line, do i not use it and just take it off?? gsr t/b has map sensor already
    and where the freak does this plug (2-wires) go?? it's a gsr harness
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    With the map sensor, you extend the wires from the firewall mounted one and use the one mounted on the gsr tb.
  3. tip
    tip Senior Member
    Ennis Texas
    or you can just get a "t" from any auto parts store and put it in line and as far as the plug ......it don't go anywhere
  4. hmglauj
    do i just leave the plug from the gsr engine harness hanging? because that's what plugged in the t/b right now
