What axle for gsr tranny with quaife
Discussion in 'HYBRID -> EG-EK / DC' started by deadazleep, Jul 6, 2008.
  1. deadazleep
    deadazleep New Member
    installed a new flywheel on my b16 with gsr tranny, discovered that both axles were in need of replacing. Drivers side was no problem using a b16 axle but the passenger side didnt fit up correctly, took the axle out of a non lsd b16 tranny that had no problems but it wont seal properly, When placed side by side my busted axles splines were shorter going into the tranny than the normal b16 so it would leak out transmission fluid. The car came with the swap so my question is what axle should i buy for it since i cant seem to find anyone localy to rebuild it
  2. 95vtec
    95vtec New Member
    try integra axels normally what you have to go with when a swap is done
  3. deadazleep
    i used one of my buddies spare axles that he had just pulled outa his b swapped eg hatch like mine and it would work but the axle would slide out jsut enough to let transmission fluid out
  4. eg6sir
    the integra axles are a tad longer than b16 axles..
  5. deadazleep
    just the splined end? i wish i woulda took a pic but the part of the axle that goes into the tranny on mine was slightly shorter than his gsrs he's using on his b16 tranny, by about a quarter of a inch. so ur saying a real b16 axle should be the way to go, and for a b16 del sol or a 99-00 Si? sorry wish i woulda been around when this car was put together so i would know first hand.
  6. 95vtec
    95vtec New Member
    88-00 with b16a mechanical parts 94-97 del sol doch vtec
    92-95 b16a electrical parts 94-95 del sol doch vtec
    96-00 b16a electrical parts 96-96 del sol doch vtec
    94-01b18c mechanical 94-01 gsr
    hope this helps
    might have to get an axle for integra and one for a del sol
  7. deadazleep
    so ur saying since the integra axle works on the drivers get a dohc del sol on the passenger?
  8. thetunersource
    thetunersource New Member
    damn axles always give me a headache
