what bearing
Discussion in 'Engine Building' started by 1bar crx, Feb 2, 2009.
  1. 1bar crx
    1bar crx old guy
    wilmington,nc
    Starting to build my motor B18b and its the first time I've used H beam rods and was wondering whatsize bearing do I use?
  2. Matts96HB
    Matts96HB . Moderator VIP
    It varies based upon your application. Wear on the crankshaft/ etc will vary depending on engine. Plastigauge the clearances and choose the appropriate bearing from there. Honda has bearings color coded for clearance ranges.
  3. 1bar crx
    1bar crx old guy
    wilmington,nc
    ok thats what i was thinking. I've done stock rebuilds but wasn't sure about what to use with the H beams. Thanks
  4. 1bar crx
    1bar crx old guy
    wilmington,nc
    Ok thats what I was thinking. I've done stock rebuilds but wasn't sure about what to use with the H beams. Thanks
  5. Matts96HB
    No problem, just be sure to use OEM Honda bearings, at least that's what I'd recommend.
