What Can Cheap Gas Do?
Discussion in 'HYBRID -> EG-EK / DC' started by c17r15, Jan 2, 2003.
  1. c17r15
    c17r15 Junior Member
    say......87 octane?
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Used in what engine? With what modifcations?
  3. c17r15
    b16a, with I/E. stock ecu fuel system and ignition system???
  4. lsvtec
    Worst case senario, preignition that buries a connection rod into the crank and tears your engine apart. Or, maybe nothing. If I were you I wouldn't run less than 89 in that engine. preferably 90 or 91.
  5. Capt. Orygun
    Capt. Orygun Win the Day
    Oregon
    91 octane on my "99b16a2" as per honda owners manual
  6. c17r15
    CAN it cause the engine to stutter at under and only under 50% throttle??
  7. Capt. Orygun
    Oregon
    ??????? if your running octane lower then what's rated for your car you run the risk of detonation. Bad stuff. The higher the octane the higher the flash point. More compression=more heat, needs higher octane. As for your your question directly, I don't think so but then again I don't know. I would imagine using lower then required quality fuel is bad regardless of what ammount of throttle your using. Is there something amiss with your car??
  8. pissedoffsol
    octane is defined as the RESISTANCE to detonation. or something :p
    basically, the higer octane you go, the less chance pre or post detonation will occur. detonation kills motors almost as fast as t9999 turbos on a cx :)
  9. chevy302dz
    chevy302dz Senior Member
    No if your engine was experiencing preignition it would ping more as your revs increased. It sounds like you have a problem with either air fuel or spark. Can you give a more detailed description of what the engine is doing and when it started?
  10. exhacker
    exhacker Member
    TN
    just my $0.02....
    i would check your plugs, make sure they are gapped properly and don't look odd (rtfm). take a look at the distributor, too. and run a few gallons of mid-grade fuel (from a good gas station), along with some water-removal stuff. you may just have a little water in the fuel. or diesel. :blink:
