What Can I Do With Integra Rs Engine
Discussion in 'HYBRID -> EG-EK / DC' started by redwidow, Feb 23, 2003.
  1. redwidow
    redwidow Member
    Hi, i have a 94 integra RS. i was wondering what can i do to get power from this egine, should i swap in Ls/Vtec or GSR/Vtec head. ;) does Ls come with Vtec? any advice will be appreciate. thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    The Integra RS/LS/GS all came with the same engine. The LS is just the most common model. You can use the engine that you have in there for an LSVTEC build. Or You could swap an engine from a 94-95 GSR. Both good options, but do some serious research before you decide on which way to go.
  3. E_SolSi
    build for turbo, do a VTEC conversion, or swap in a VTEC engine
