what causes this...
Discussion in 'HYBRID -> EG-EK / DC' started by D See 2, Nov 4, 2002.
  1. D See 2
    D See 2 Senior Member
    Baltimore, MD
    ok, for the past 2 weeks, as i have been driving, my car will all of a sudden have a really sharp jolt and the motor shuts off for a split second. one time when it did it, the motor completely shutoff while driving on the freeway. any pointers? no check engine light... 93 octane fuel... ;)
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    check your ignition timing
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    I bet something in the ignition is wrong, check your plugs ans wires. Maybe check your cap and rotor.
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    i vote cap and rotor... same thing was happening to mine, until one day it wouldn't start anymore.. the rotor ended up breaking off in the cap! hehe, the parts are cheap for a rotor and cap.
  5. sportlinecrx
    sportlinecrx Banned
    that is the SAME exact problem that i had...it was the IGNITER (inside your distributor). costs me around $100 to get it replaced by a mechanic. its worth replacing just in case. it got to the point where my engine would die at 80mph! it felt like the engine was seizing. this igniter problem is common in older hondas. there was even a recall on them for the 4th gen civics.
  6. lsvtec
    And the G2 Integras. It's easy enough to change yourself, but if you get a Honda part it will cost more than $100.
