What Clutch for a stock 1990 Civic LX 1.5 liter
Discussion in 'Civic and CRX - EF' started by Thurobred, Feb 22, 2008.
  1. Thurobred
    Thurobred Thurobred
    Milwaukee
    What is a good replacement clutch for a bone stock 1990 Honda civic 1.5 liter? What else can i do to the five speed to freshen it up?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    if your gona keep it stock a oem clutch will be beast
  3. smok155
    smok155 New Member
    madera ca
    you can get lots of things on e bay
  4. roninallout79
    roninallout79 Plan B
    GER friggin MANY
    That would be my suggestion go to ebay look around for a Exedy or XTD. I was just researching your clutch and XTD has a complete kit with throw out bearing, pilot bearing, stage 2 clutch, pressure plate, and the alignment tool. When you yank your tranny make sure to inspect the oil. If its dirty change it with a good name oil. My other suggestion would look around for a LS or D16 tranny. You need the flywheel too make that swap because the D16 clutch is slightly bigger and the tranny input shaft is about 1/16" longer than the D15 (at least thats what I measured last night at like 4am might not be so dont quote me on that part) good luck
    TRU
  5. AHHVTEC
    Alabama
    the ls tranny wont fit
  6. 92civicb18b1
    92civicb18b1 The Trisexual
    I know the LS won't fit and I'm pretty sure his stock clutch and flywheel are completely compatible with any D series trans. I was never a D series guy buy I've read a lot and don't remember anything about having to use alternate flywheels/clutches just for swapping trans's.
    But to smoothen it up a bit, flush and replace the trans oil. If you're trying to spend a couple bucks, a lightweight flywheel will make it feel like your car's a little quicker, might be a little easier to get the rpms up also.
  7. roninallout79
    GER friggin MANY
    That was my bad I didnt mean to put the LS in there I posted that around 5 am without any sleep in a couple of days sorry my bad
  8. AHHVTEC
    Alabama
    it happens
  9. roninallout79
    GER friggin MANY
  10. Thurobred
    Thurobred Thurobred
    Milwaukee
    Thanks everyone; you've all been helpful,
